[Fwd: Re: [postgis-users] dataset for postgis]]
Hao Ding
hdi12 at it.canterbury.ac.nz
Thu Jul 4 18:38:21 PDT 2002
The previous error was disapeared by adding a port in the CONNECTION
info. This time I got another error
msPOSTGISLayerWhichShapes(): Query error. prep_DB:Error executing
POSTGIS DECLARE statement (0.6 failed - retried 0.5 and it failed too).
DECLARE mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from
airports WHERE the_geom && setSRID('BOX3D(388013.643812817
5200395.13465842,500802.348432817 5313156.99196842)'::BOX3D,
find_srid('','airports','the_geom') )
How to deal with it? Thanks!
Hao
-------- Original Message --------
I got the error message when querying the map using itasca demo application
msPOSTGISLayerOpen(): Query error. Error parsing POSTGIS connection
information.
The following is the Layer I set up in the mapfile
LAYER
NAME "airports"
CONNECTIONTYPE postgis
CONNECTION "user=ryan dbname=gisdb host=localhost"
TYPE POINT
DATA "the_geom from airports"
STATUS ON
CLASS
NAME 'Airports'
COLOR 128 255 164
SYMBOL 'circle'
SIZE 7
TEMPLATE "airports.html"
END
HEADER "airports_header.html"
FOOTER "airports_footer.html"
TOLERANCE 5
METADATA
WMS_TITLE "Airports"
WMS_ABSTRACT "Airport runways for Itasca County."
WMS_SRS "EPSG:26915"
END
END
Is there somewhere wrong? Do I have to add a port number in the
CONNECTION info? How do I know the port the postgis is running?
Thanks
Hao
Tyler Mitchell wrote:
> Hi Hao, we can talk about it off of the list if you'd like. It's not
really
> Postgis related. You will need to setup a layer that reads your postgis
> data first.
>>-----Original Message-----
>>From: postgis-users-admin at postgis.refractions.net
>>[mailto:postgis-users-admin at postgis.refractions.net]On Behalf Of Hao
>>Ding
>>Sent: Thursday, July 04, 2002 3:44 PM
>>To: themitchells at telus.net
>>Cc: postgis-users at postgis.refractions.net
>>Subject: [Fwd: Re: [postgis-users] dataset for postgis]
>>Hi Tyler,
>>I have converts the shapefile to sql file successfully. Now Could you
>>tell me how to set up WMS server mapfile in Mapserver for the data?
>>Thanks a lot!
>>Hao
>>Subject: Re: [postgis-users] dataset for postgis
>>Date: Fri, 05 Jul 2002 10:21:51 +1200
>>From: Hao Ding <hdi12 at it.canterbury.ac.nz>
>>Reply-To: postgis-users at postgis.refractions.net
>>Organization: University of Canterbury
>>To: Tyler Mitchell <themitchells at telus.net>
>>CC: postgis-users at postgis.refractions.net
>>References: <3D1F480A at webmail>
>><20020702050233.RUUD5909.priv-edtnes16-hme0.telusplanet.net at there>
>>Hi,
>>I tried creating a sql file from Itasca demo shapefile, but got
>>"Segmentation fault" error. Are there some faults in the command?
>>cosc273:data$ shp2pgsql airports airports gisdb > airports.sql
>>Segmentation fault
>>Thanks,
>>Hao
>> > hi Hao,
>> > Do you have the Itasca demo data for Mapserver? You can use the
>>postgis tool
>> > called 'shp2pgsql' (I can give you more info if needed) to
>>create a
>>SQL file
>> > and then you can load the sql commands into postgis.
>> > I don't have time right now but I'll gladly help walk you
>>through it.
>> I even
>> > have a set of SQL files for the demo data available if you
>>want them.
>> Just
>> > let me know.
>> > Tyler
>> > On Monday 01 July 2002 09:44 pm, you wrote:
>> >>Hi all,
>> >>Now I am implementing a OGC WMS client application. I
>>have installed
>> >>MapServer as WMS server and postgis as back-end
>>datasource. Where can I
>> >>find some spatial dataset that can be stored in the
>>postgis and used by
>> >>MapServer? If I get some dataset, how to put them into
>>postgis and make
>> >>them work with MapServer?
>> >>These questions could be simple for someone, but I am a new user of
>> >>MapServer and postgis, and the documents don't provide me all
>>information I
>> >>am hunting. Thanks very much for any help?
>> >>Regards,
>> >>Hao
>> >>_______________________________________________
>> >>postgis-users mailing list
>> >>http://postgis.refractions.net/mailman/listinfo/postgis-users
