[postgis-users] shp2pgsql crashes
Steffen Macke sdteffen at web.de
Mon Jul 15 08:28:22 PDT 2002
> Hi, these are the shapefiles from
> http://www.nationalatlas.gov/atlasftp.html
> which crashed shp2pgsql:
> Public Land Survey (plss00p020)
I tested this one and it worked. However the file
contains NULL values, so you'll need the CVS version
of shp2pgsql to run it successfully. Can you make sure that you're
actually using the shp2pgsql version from CVS? Maybe there's an
older one lurking somewhere in your path.
Steffen
