[postgis-users] shp2pgsql crashes
David Garnier
david.garnier at etudier-online.com
Tue Jul 16 02:01:51 PDT 2002
I remember trying to import .dbf files in Access, in order to convert them to a .cvs file. Access categorically refused to import the file if the filename was longer than 8.3. Shortening the filename did work. So maybe this is something related to the .dbf format.
Best Regards,
David Garnier
On Tue, 16 Jul 2002 00:37:15 -0600
Alex Rice <alex_rice at arc.to> wrote:
> OK, I found the problem. This is a strange one. Because the ESRI
> Shapefile specification says 8.3 filenames are required, I figured I
> would shorten the filenames I was having problems with, and then I was
> able to import no problems. The strange thing is that some of the
> shapefiles which did import OK previously were longer than 8.3, some
> were 10.3, and they all had DBF feature files too.
> I am guessing the problem seems to be in dbfopen.c -> DBFOpen(). My C is
> not too strong though. maybe someone can add some checking for long
> filenames in there? Oh, also the HFS+ filesystem on MacOS X is
> case-insensitive. I am wondering if that might be a factor as well?
> On Monday, July 15, 2002, at 10:01 PM, Steffen Macke wrote:
> > Maybe. What locale are you using? Sometimes this gives strange effects.
> BTW How can I find this out? My system preferences are set to US
> English. I don't know how similar Mac OS X is to other Unixes, wrt
> locale stuff. It does use Unicode pretty extensively. This is Apple's
> GCC "version gcc-934.3, based on gcc version 2.95.2". There are man
> pages for setlocale() and related functions, but there is also part of
> CoreServices called "Locale Utilities", which seems to interface with
> the standard C locale functions.
> Alex Rice, Software Developer
> Architectural Research Consultants, Inc.
> alex_rice at arc.to
> alrice at swcp.com
> postgis-users mailing list
