[postgis-users] Sun Os compilation problem
Virgilio Ramos
vramos at icnet.com.ve
Fri Jul 26 08:41:53 PDT 2002
Hi Folks
Im trying compiling postgis 0.7.1 in a Ultra-250
SunOS 5.8 Generic_108528-11 sun4u sparc SUNW
but when i do make i get:
gcc -Wall -Wmissing-prototypes -Wmissing-declarations -fPIC -g -I.
-I../../src
/include -I/usr/local/readline/include/ -DFRONTEND
-DSYSCONFDIR='"/usr/local/pgs
ql/etc"' -c -o postgis_ops.o postgis_ops.c
postgis_ops.c: In function `ggeometry_compress':
postgis_ops.c:826: structure has no member named `pred'
postgis_ops.c:836: structure has no member named `pred'
postgis_ops.c:842: structure has no member named `pred'
postgis_ops.c:848: warning: assignment makes integer from pointer
without a cast
postgis_ops.c:852: warning: assignment makes integer from pointer
without a cast
postgis_ops.c: In function `ggeometry_consistent':
postgis_ops.c:876: structure has no member named `pred'
postgis_ops.c:881: structure has no member named `pred'
postgis_ops.c:887: structure has no member named `pred'
postgis_ops.c: In function `rtree_union':
postgis_ops.c:1060: structure has no member named `pred'
postgis_ops.c:1065: structure has no member named `pred'
postgis_ops.c: In function `rtree_penalty':
postgis_ops.c:1086: structure has no member named `pred'
postgis_ops.c:1090: structure has no member named `pred'
postgis_ops.c: In function `rtree_picksplit':
postgis_ops.c:1130: structure has no member named `pred'
postgis_ops.c:1132: structure has no member named `pred'
postgis_ops.c:1177: structure has no member named `pred'
postgis_ops.c:1179: structure has no member named `pred'
postgis_ops.c:1183: structure has no member named `pred'
postgis_ops.c:1185: structure has no member named `pred'
postgis_ops.c:1223: structure has no member named `pred'
postgis_ops.c:1248: warning: assignment makes integer from pointer
without a cast
postgis_ops.c:1249: warning: assignment makes integer from pointer
without a cast
gmake: *** [postgis_ops.o] Error 1
yhe same error occurs when try with postgis 0.6.2
Any clues
TIA
Virgilio
