[postgis-users] using avpgcon
Armin Burger
armin.burger at libero.it
Fri Jul 26 07:27:10 PDT 2002
Robert,
you could try the latest version
http://digilander.iol.it/arminburger/download/avpgcon-0.6.1.zip
I added some basic debugging function. The SQL statements are logged
into a text file in the system TEMP dir. You have to set the
'enableDebug' key in the ini file to TRUE.
You could then try if the SQL statements work when running them via
psql.
In this version I also changed the queries to retrieve tables and
columns. For that, the system tables ('pg_...') are read, so the user
needs select grants on them.
Armin
> Armin et al,
> I am trying to get the avpgcon utility to work in ArcView 3.2, and get
the
> following messqage after clicking the 'Table' button in the add
postgis
> theme
> dialog:
> "could not send startup packet: the system cannot find message for
message
> number 0x%1 in message file %2. (0x0000013D) "
> Anyone have a clue as to what I am doing wrong?
> Thanks,
> rob
> postgis-users mailing list
