[postgis-users] Installation - help
Riyaz Prasla riyazprasla at yahoo.com
Mon Jul 29 14:52:50 PDT 2002
I am not getting that error anymore but I am getting a
different one now. So when I type: createlang plpgsql
test --pglib /usr/local/pgsql/lib, I get the following
error:
Connection to database 'test' failed.
connectDB() -- connect() failed: Connection refused
Is the postmaster running at 'localhost' and accepting
connections on Unix socke
t '5583'?
Cannot install language
Even though my postmaster is running. I have checked
that by connecting to the database by this command:
psql mydatabase
Also, I am running Linux on a Cobalt Qube.I have
installed the 7.2 version of postgres and trying to
install 0.7.1 version of postgis.
Any help on this, appreciated.
-Riyaz.
--- Chris Hodgson <chodgson at refractions.net> wrote:
> Sorry, please give us some more info to work with
> here... what platform are
> you on? where exactly are the pglibs? have you had
> other versions of
> postgres installed before (could  you be using
> createlang from a different
> version of postgres than your libraries are?), did
> the createdb command not
> give you any problems? (that seems weird, it should
> need the same libraries)
> Also, you need to be a postgres user with full
> access permissions (root
> postgres user is simplest) in order to run the
> createlang command. (this
> isn't the right error message for that problem, but
> I've never seen this
> message before, so I'm grabbing at straws here)
> If none of this helps, perhaps you should post to
> the postgres list, as your
> problem is more specific to postgres than to
> postgis...
> Chris
> ----- Original Message -----
> From: "Riyaz Prasla" <riyazprasla at yahoo.com>
> To: <postgis-users at postgis.refractions.net>
> Sent: Monday, July 29, 2002 11:14 AM
> Subject: Re: [postgis-users] Installation - help
> > I tried setting the path but still gives the same
> > error.
> > Thanks,
> > Riyaz
> wrote:
> > > Where did you install postgres to? It seems that
> the
> > > postgres libraries are not in your
> > > LD_LIBRARY_PATH... they should either be in the
> > > 'lib' subdirectory of where you installed
> postgres,
> > > or in /usr/lib somewhere. Where-ever they are,
> you
> > > need to find them, and add their location to
> either
> > > your LD_LIBRARY_PATH, or your PGLIB environment
> > > variable. Something like:
> > > set
> LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/pgsql/lib
> > > should do it, with the correct location in place
> of
> > > /opt/pgsql/lib, depending on your shell...
> > > Chris
> > >   From: Riyaz at umapinc.com
> > >   To: postgis-users at postgis.refractions.net
> > >   Sent: Monday, July 29, 2002 10:31 AM
> > >   Subject: [postgis-users] Installation - help
> > >   Hello,
> > >   I am getting the error below when I try to run
> > > this command:   createlang plpgsql databasename
> > >   Cannot determine PostgreSQL lib directory
> (PGLIB).
> > >   You must identify the PGLIB either with a
> --pglib
> > > option
> > >   or by setting the PGLIB environment variable.
> > >   Any help on this?
> > >   Thanks,
> > >   Riyaz
> > __________________________________________________
> > Do You Yahoo!?
> > Yahoo! Health - Feel better, live better
> > http://health.yahoo.com
> > postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
Do You Yahoo!?
