[postgis-users] Installation - help
Chris Hodgson
chodgson at refractions.net
Mon Jul 29 11:27:44 PDT 2002
Sorry, please give us some more info to work with here... what platform are
you on? where exactly are the pglibs? have you had other versions of
postgres installed before (could you be using createlang from a different
version of postgres than your libraries are?), did the createdb command not
give you any problems? (that seems weird, it should need the same libraries)
Also, you need to be a postgres user with full access permissions (root
postgres user is simplest) in order to run the createlang command. (this
isn't the right error message for that problem, but I've never seen this
message before, so I'm grabbing at straws here)
If none of this helps, perhaps you should post to the postgres list, as your
problem is more specific to postgres than to postgis...
Chris
----- Original Message -----
To: <postgis-users at postgis.refractions.net>
Sent: Monday, July 29, 2002 11:14 AM
Subject: Re: [postgis-users] Installation - help
> I tried setting the path but still gives the same
> error.
> Thanks,
> Riyaz
> --- Chris Hodgson <chodgson at refractions.net> wrote:
> > Where did you install postgres to? It seems that the
> > postgres libraries are not in your
> > LD_LIBRARY_PATH... they should either be in the
> > 'lib' subdirectory of where you installed postgres,
> > or in /usr/lib somewhere. Where-ever they are, you
> > need to find them, and add their location to either
> > your LD_LIBRARY_PATH, or your PGLIB environment
> > variable. Something like:
> > set LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/pgsql/lib
> > should do it, with the correct location in place of
> > /opt/pgsql/lib, depending on your shell...
> > Chris
> > From: Riyaz at umapinc.com
> > To: postgis-users at postgis.refractions.net
> > Sent: Monday, July 29, 2002 10:31 AM
> > Subject: [postgis-users] Installation - help
> > Hello,
> > I am getting the error below when I try to run
> > this command: createlang plpgsql databasename
> > Cannot determine PostgreSQL lib directory (PGLIB).
> > You must identify the PGLIB either with a --pglib
> > option
> > or by setting the PGLIB environment variable.
> > Any help on this?
> > Thanks,
> > Riyaz
> __________________________________________________
> Do You Yahoo!?
> Yahoo! Health - Feel better, live better
> http://health.yahoo.com
> postgis-users mailing list
