[postgis-users] Installation - help
Riyaz Prasla
riyazprasla at yahoo.com
Mon Jul 29 11:14:29 PDT 2002
I tried setting the path but still gives the same
error.
Thanks,
Riyaz
--- Chris Hodgson <chodgson at refractions.net> wrote:
> Where did you install postgres to? It seems that the
> postgres libraries are not in your
> LD_LIBRARY_PATH... they should either be in the
> 'lib' subdirectory of where you installed postgres,
> or in /usr/lib somewhere. Where-ever they are, you
> need to find them, and add their location to either
> your LD_LIBRARY_PATH, or your PGLIB environment
> variable. Something like:
> set LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/pgsql/lib
> should do it, with the correct location in place of
> /opt/pgsql/lib, depending on your shell...
> Chris
> ----- Original Message -----
> From: Riyaz at umapinc.com
> To: postgis-users at postgis.refractions.net
> Sent: Monday, July 29, 2002 10:31 AM
> Subject: [postgis-users] Installation - help
> Hello,
> I am getting the error below when I try to run
> this command: createlang plpgsql databasename
> Cannot determine PostgreSQL lib directory (PGLIB).
> You must identify the PGLIB either with a --pglib
> option
> or by setting the PGLIB environment variable.
> Any help on this?
> Thanks,
> Riyaz
__________________________________________________
Do You Yahoo!?
Yahoo! Health - Feel better, live better
http://health.yahoo.com
