[postgis-users] Problems with PostGIS and Proj4 on Cygwin
Armin Burger
armin.burger at libero.it
Tue Jun 4 14:43:37 PDT 2002
Hello all,
I compiled successfully Postgres 7.2/PostGIS 0.7.1 on Cygwin/Windows NT. The
system runs fine, only there are problems with re-projection using the Proj 4
functionality compiled into PostGIS.
I tested the re-projection creating a view like
CREATE VIEW corinegb
AS SELECT code,landcover,transform(the_geom, 102091) AS the_geom FROM corine;
and then selecting the records of that view. I got an error like the
following
NOTICE: Error occurred while executing PL/pgSQL function transform
NOTICE: line 2 at return
ERROR: transform: couldnt project polygon;
I tried another projection and I could query the view data. But when
converting them to a shapefile with pgsql2shp, the shapefile seemed to be
corrupt. ArcView only shows all polygons condensed to one line and then
crashes.
Running Postgres/PostGIS on Linux with the same data and queries works fine
without any problems.
Any ideas what could cause the problems on Cygwin? Problems with the Proj 4
installation?
Armin
Armin Burger
Via della fiera, 7 - I-39050 Cornaiano BZ - Italia
_
