[postgis-users] Problems with PostGIS and Proj4 on Cygwin
Norman Vine
nhv at cape.com
Wed Jun 5 03:26:27 PDT 2002
Armin Burger writes:
>I used Postgres 7.2.1/PostGIS 0.7.1 and Proj4.4.5. I tried to reproject
>an Italian projection system (it is similar to UTM).
>I had to modify a bit the makefile for Proj4 in order to continue the
>'make install' procedure, but then it seemed to work. Maybe the
>compilation/installation was not complete, anyway. I don't if that
>matters, but I could not compile the dynamic libraries for Proj4, only
>the static ones were produced. But PostGIS compiled with the USE_PROJ=1
>option without complaining.
>I will also try to test the cygwin version of Norman Vine.
PostGIS should work fine with the static proj library
FWIW It is fairly easy to make a DLL for Cygwin from a static library
with the 'current' Cygwin distribution
here is the command I use to do this for proj
this will ONLY work after a successful 'make' in the top level
proj source directory has built the 'static' link library
also note my use of the 'cyg' prefix for the dll
gcc -shared -o cygproj.dll \
-Wl,--out-implib=libproj.dll.a \
-Wl,--export-all-symbols \
-Wl,--enable-auto-import \
-Wl,--whole-archive ./src/.libs/libproj.a \
-Wl,--no-whole-archive /lib/libcygwin.a
You will need to copy the resulting DLL into your path
and the resulting linker lib < libproj.dll.a > to where 'ld' will pick it up
FYI - All the above is 'buried' in the 'ld' documentation
Cheers
Norman
