[postgis-users] Function for creating TIN using tripack fortran codes
Paul Ramsey
pramsey at refractions.net
Wed Jun 5 08:12:48 PDT 2002
Wow, we are getting advanced functionality thoughts already! I suppose
one open question is "what is the best way to store a TIN in a spatial
database"? As a table of faces? As a single object? Too bad both the GPC
and tripack code is not quite open-source enough for actual inclusion in
the base package. Fortunately, the GEOS project (the new C++ JTS) will
provide us with the basic spatial operators.
Does anyone have any thoughts, or academic references to ideas on
storing topological structures in a spatial DB? I am thinking
coverage-style topologies in particular. That seems like an obvious and
useful point of attack once SFSQL is covered.
P.
Hisaji ONO wrote:
> Hello.
> I tried to create a function for creating TIN from MULTIPOINT
> experimentally using tripack(fortran TIN library ) available from
> http://cran.r-project.org/src/contrib/tripack_1.2-3.tar.gz. This function
> outputs TIN as a MULTIPOLYGON. I used tripack's two fortan codes. They are
> ACM's, and free for ***noncommercial*** use.
> I attached two files "tin.c" and "Makefile.g77", a modified original make
> file. For compiling my program, please execute "make -f Makefile.g77" in
> PostGIS's source existing directory.
> For defining this function, run following function in psql client
> program(this is an example in Cygwin Environment).
> CREATE FUNCTION tin(GEOMETRY)
> RETURNS GEOMETRY
> AS 'C:/cygwin/usr/src/postgresql-7.2.1/contrib/postgis-0.7.1/postgis.dll',
> 'create_tin'
> LANGUAGE 'c' with (isstrict);
> For using this function:
> select tin(collect(the_geom)) from point_table;
> For creating TIN, your need more than 3 points.
> Sorry, I'm newbie for creating PostgreSQL's function by C, I don't know
> how to output each triangle with its ID, useful triangle's info(neighbor
> triangles, its lines' IDs and its points' IDs) in this function. Could you
> tell me any suggestion about this?
> Thanks for Mr. Nicholas Ribot's programs for functions using GPC, I've
> managed to create this program.
> Best Regards.
> tin.c Type: unspecified type (application/octet-stream)
> Encoding: quoted-printable
> Makefile.g77 Type: unspecified type (application/octet-stream)
