[postgis-users] Accessing PostGIS from ArcView
Cedric BERNIER cedric.bernier at thales-is.com
Mon Jun 10 01:51:06 PDT 2002
hi Armin,
Have you tried to use this extension with ArcMap, I mean ArcGIS 8.1 or 8.2 ?
You say you don't use ODBC but is your database is on the same system than your
AcrView software ? I mean do you use cygwin or such an emulator ?
In this case, do you think it could work on a remote database configuration.
I mean : data server PostGIS on Linux and Arcview on windows?
Thank you for your investigation !
Armin Burger a écrit :
> Hi all,
> I have been working on an extension for ArcView 3 to access PostGIS data. At
> the moment the extension offers the functionality to
> * Retrieve PostGIS data as shapefile and load them into ArcView,
>   including data refresh
> * Re-project PostGIS data and create shapefile
> * Identify and editing of attribute information directly on the database
> If you are interested, you can download the extension including source code
> and needed libraries at
> http://digilander.iol.it/arminburger/download/avpgcon.zip
> The database access is without ODBC, using the libpq.dll functionality.
> Future plans are to implement a visualization of PG data as graphics in
> ArcView (instead of temporary shapefiles). The only part missing for that is
> a fast and reliable algorithm to convert PostGIS geometry for different types
> into ArcView Avenue representation. If anyone has already finished such work
> successfully and would like to contribute, I would be glad to include it.
> The extension uses the pgsql2shp.exe to create the shapefiles. That will
> always open a command window what is not very elegant. To avoid this, the
> compilation of a library instead of the executable would be necessary. Can
> anybody tell me how much effort it would be to change the C code in order to
> compile as library?
> Any feedback is very welcome.
> Armin
>  Armin Burger
>  Via della fiera, 7 -  I-39050 Cornaiano BZ -  Italy
> PS: I hope the Refractions people don't mind me using their elefantino logo
> in one dialog, I liked it too much.
> postgis-users mailing list
Type: text/x-vcard
Desc: Carte pour Cedric BERNIER
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20020610/13066652/attachment.vcf>
