[postgis-users] Computing the overal bounding box
David Garnier
david.garnier at etudier-online.com
Tue Jun 11 13:50:02 PDT 2002
It works very well. but you have one spurious parenthesis. Here is a
corrected version:
SELECT max(ymax(box3d(the_geom))), min(xmin(box3d(the_geom))),
min(ymin(box3d(the_geom))), max(xmax(box3d(the_geom))) FROM table
This version also returns first the upper left corner then the lower right
corner in Latitude-Longitude order.
Thanks,
David Garnier
Le Mardi 11 Juin 2002 22:40, Chris Hodgson a écrit :
> Something like:
> SELECT min( xmin( box3d( the_geom ) ) ), min( ymin( box3d( the_geom ) ) ),
> max( xmax( (box3d( the_geom ) ) ), max( ymax( box3d( the_geom ) ) ) FROM
> table
> should do it relatively efficietly, I think. The following:
> SELECT box3d( collect( the_geom ) ) FROM table
> would work, but I wouldn't recommend it for large tables (or at all,
> really) - the entire table will be put into one geometry, by adding one row
> at a time... that will suck up a lot of memory!
> Chris Hodgson
> David Garnier wrote:
> > Hello,
> > I have a large amount of data loaded in my PostGis DB, and I'd like to
> > compute the overall bounding box enclosing every feature using a SQL
> > query.. Speed isn't a real concern.
> > Best regards,
> > David Garnier
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
