[postgis-users] Newbie: Windows Install Help
Norman Vine
nhv at cape.com
Mon Jun 24 17:50:53 PDT 2002
Chris Hodgson writes:
>It is not necessary to compile any of these yourself, or even
>to install the source.
>You do need to
>run ./configure in the postgres source directory, because some
>options in the
>makefile.global are used by postgis in its makefile. Then you
>just have to untar
>the postgis source into the postgres tree, and make it.
EXACTLY !!
>"Obe, Regina DND\\MIS" wrote:
>> The following packages or later are required to build and/or execute
>> Cygwin PostgreSQL:
>> crypt 1.0.1
>> cygipc 1.09
>> readline 4.2-3
>> zlib 1.1.3
If the linker complains about any of these rerun the Cygwin setup program
and download the package
see http://cygwin.com/packages/ if you do not know the name of the
required package for a 'missing' library
the Cygwin specific postgres documentation in in /usr/doc/cygwin
Note there is a list for Cygwin related PostgreSQL questions
pgsql-cygwin at postgresql.org
Norman
