[postgis-users] MORE Newbie: Windows Install Help
Paul Ramsey pramsey at refractions.net
Wed Jun 26 11:27:35 PDT 2002
Apologies, makefile patch committed this time.
P.
Norman Vine wrote:
> Hankley, Chip writes:
> >Thanks, that #$@ Readme file again! What's wrong w/ me?
> >I made those changes, but I'm still bombing out. Here's how it
> >looks now.
> >BTW, I had to load PERL to get the make to work...
> Nit picking here but ...
> Make does not need Perl but gnu automake does
> automake is only needed by the autoconf process
> > that's one thing that
> >hasn't been noted as "req'd" for the Cygwin download. I'm
> >going to *try* to
> >write a 'non-unix-users' guide to installing this.
> >$ make install
> >make -C loader
> >make[1]: Entering directory
> >`/usr/src/postgresql-7.2.1-2/contrib/postgis-0.7.1/loader'
> >make[1]: Nothing to be done for `all'.
> >make[1]: Leaving directory
> >/bin/sh.exe ../../config/install-sh -c -m 644 libpostgis.a
> >/usr/lib/contrib/libpostgis.a
> >/bin/sh.exe ../../config/install-sh -c -m 755 postgis.dll
> >/usr/lib/contrib/postgis.dll
> >/bin/sh.exe ../../config/install-sh -c -m 644 ./README.postgis
> >/usr/doc/postgresql-/contrib
> >/bin/sh.exe ../../config/install-sh -c -m 644 postgis.sql
> >/usr/share/postgresql/contrib
> >/bin/sh.exe ../../config/install-sh -c -m 644 postgis_undef.sql
> >/bin/sh.exe ../../config/install-sh -c -m 644 spatial_ref_sys.sql
> >/bin/sh.exe ../../config/install-sh -c -m 644 README.postgis
> >make -C loader install
> >/bin/sh.exe ../../../config/install-sh -c pgsql2shp /usr/bin
> >chmod: changing permissions of `/usr/bin/#inst.1624#': No such file or
> directory
> >make[1]: *** [install] Error 1
> >make: *** [install] Error 2
> Arrgh... You are being bitten by the Windows .exe extension thing
> I thought I had submitted this patch before
> < see attached >
> Norman
>    Makefile    Type: unspecified type (application/octet-stream)
>            Encoding: quoted-printable
      __
     | Paul Ramsey
     | Refractions Research
     | Email: pramsey at refractions.net
     | Phone: (250) 885-0632
     \_
