AW: [postgis-users] PostGIS 0.7 another compilation error
Oliver Heimann Oliver.Heimann at vodafone.de
Tue May 7 05:39:40 PDT 2002
But that's exactly, what i've done.
I've edited the PostGIS Makefile and have changed the USE_PG72 variable
to 1, see below.
Thanks
Oliver
# Configuration Directives
# Set USE_PG72 to 1 for PostgreSQL version >= 7.3
USE_PG72=1
>With USE_PG72=1 you are able to compile.
>Horst
>>-----Ursprüngliche Nachricht-----
>>Von: Oliver Heimann [mailto:Oliver.Heimann at vodafone.de]
>>Gesendet am: Dienstag, 7. Mai 2002 08:33
>>An: postgis
>>Betreff: [postgis-users] PostGIS 0.7 another compilation error
>>Hi,
>>i also tried to compile PostGIS 0.7 against PostgreSQL 7.2 and 7.2.1 but
>>i got errors too.
>>I tried to compile it under SuSE Linux 8.0 and Sun Solaris 8.
>>When i compile PostGIS 0.7 against PostgreSQL 7.1.3 (USE_PG72=0) all
>>works fine.
>>It seems to be a problem with GIST.?
>>Greetings
>>Oliver
