[postgis-users] 0.7.0 make install error (cygwin)
Paul Ramsey
pramsey at refractions.net
Wed May 8 09:19:16 PDT 2002
Yuck,
If any cygwin experts know what is wrong with my install target, the
help would be appreciated. It's pretty vanilla stuff though, so I do not
know what could be causing these wierd executable names to be popping
up...
Paul
m.tondorf at online.de wrote:
> I am using PostGis with cygwin. 0.6.9 with Postgres 7.1.2 works
> fine. Today I tried to upgrade to Postgis 0.7 with Postgres 7.2.
> I get an error when trying to install postgis.
> - Installed cygwin without Postgres
> - Unzipped Postgres
> - ./configure --enable-odbc --with-java - make
> - make install
> - initdb
> - Unzipped Postgis in contrib
> - changed USE_PG72=1 in makefile
> - make
> - make install -> error
> mtondorf at SPREE /usr/src/postgresql-7.2/contrib/postgis-0.7.0
> $ make install
> make -C loader
> make[1]: Entering directory
> `/usr/src/postgresql-7.2/contrib/postgis-0.7.0/loader'
> make[1]: Nothing to be done for `all'.
> make[1]: Leaving directory
> /bin/sh.exe ../../config/install-sh -c -m 644 libpostgis.a
> /usr/local/pgsql/lib/contrib/libpostgis.a
> /bin/sh.exe ../../config/install-sh -c -m 755 postgis.dll
> /usr/local/pgsql/lib/contrib/postgis.dll
> /bin/sh.exe ../../config/install-sh -c -m 644 ./README.postgis
> /usr/local/pgsql/doc/contrib
> /bin/sh.exe ../../config/install-sh -c -m 644 postgis.sql
> /usr/local/pgsql/share/contrib
> /bin/sh.exe ../../config/install-sh -c -m 644 postgis_undef.sql
> /bin/sh.exe ../../config/install-sh -c -m 644 spatial_ref_sys.sql
> /bin/sh.exe ../../config/install-sh -c -m 644 README.postgis
> make -C loader install
> /bin/sh.exe ../../../config/install-sh -c pgsql2shp /usr/local/pgsql/bin
> chmod: changing permissions of `/usr/local/pgsql/bin/#inst.1576#': No
> such fileor directory
> make[1]: *** [install] Error 1
> make: *** [install] Error 2
> Verzeichnis von C:\Programme\cygwin\usr\local\pgsql\bin
> 08.05.2002 17:26 <DIR> .
> 08.05.2002 17:26 <DIR> ..
> 08.05.2002 17:02 121.385 #inst.1012#.exe
> 08.05.2002 17:10 121.385 #inst.1576#.exe
> 08.05.2002 17:01 104.318 #inst.1652#.exe
> 08.05.2002 16:41 4.864 createdb
> 08.05.2002 16:41 6.482 createlang
> 08.05.2002 16:41 6.344 createuser
> 08.05.2002 17:26 0 dir.lst
> 08.05.2002 16:41 3.262 dropdb
> 08.05.2002 16:41 5.969 droplang
> 08.05.2002 16:41 3.441 dropuser
> 08.05.2002 16:40 286.629 ecpg.exe
> 08.05.2002 16:41 27.185 initdb
> 08.05.2002 16:41 4.705 initlocation
> 08.05.2002 16:41 2.990 ipcclean
> 08.05.2002 17:01 121.385 pgsql2shp
> 08.05.2002 16:41 2.385 pg_config
> 08.05.2002 16:41 9.471 pg_ctl
> 08.05.2002 16:41 159.087 pg_dump.exe
> 08.05.2002 16:41 7.347 pg_dumpall
> 08.05.2002 16:41 24.369 pg_id.exe
> 08.05.2002 16:41 35.083 pg_passwd.exe
> 08.05.2002 16:41 95.788 pg_restore.exe
> 08.05.2002 16:40 1.865.545 postgres.exe
> 08.05.2002 16:40 104 postmaster.lnk
> 08.05.2002 16:41 156.459 psql.exe
> 08.05.2002 16:41 4.321 vacuumdb
> 26 Datei(en) 3.180.303 Bytes
> 2 Verzeichnis(se), 15.021.035.520 Bytes frei
> Cygwin /etc/profile:
> PATH="/usr/local/bin:/usr/bin:/bin:$PATH"
> PATH=/usr/local/pgsql/bin:/usr/local/pgsql/lib:$PATH
> PGDATA=/usr/local/pgsql/data LD_LIBRARY_PATH=/usr/local/pgsql/lib
> export LD_LIBRARY_PATH PGDATA USER="`id -un`"
> postgis-users mailing list
