[postgis-users] 0.7.0 make install error (cygwin)
Norman Vine
nhv at cape.com
Wed May 8 10:15:35 PDT 2002
Paul Ramsey writes:
>If any cygwin experts know what is wrong with my install target, the
>help would be appreciated. It's pretty vanilla stuff though,
>so I do not
>know what could be causing these wierd executable names to be popping
>up...
>Paul
Paul
Give me a couple of days to get clear of somestuff
then I will try upgrade to 7.2 and post all 'if any' Cygwin
specific patches that I have to make
FWIW - This will all be coordinated with the
'Cygwin PostgreSQL port maintainers'
In the meantime the standard install script trips up on
the '.exe' extension. Probably easiest for Cygwin users
to just manually indicate this in their local Makefiles
ie add '.exe' to all the executable names wherever they are used
within the makefile
pgsql2shp
becomes
pgsql2shp.exe
Hopefully I will have a more 'elegant' solution shortly
Norman
