[postgis-users] 0.7.0 make install error (cygwin)
Norman Vine
nhv at cape.com
Wed May 8 16:13:07 PDT 2002
Norman Vine wrote:
>Paul Ramsey writes:
>>If any cygwin experts know what is wrong with my install target,
>In the meantime the standard install script trips up on
>the '.exe' extension. Probably easiest for Cygwin users
>to just manually indicate this in their local Makefiles
Hi all
attached find the Makefile I used to create a set of Cygwin PostGIS
executables
I don't think that this should break non-Cygwin builds
Also I have temporarily placed a Cygwin binary distribution package
of PostGIS to include the Proj files at my website
http://www.vso.cape.com/~nhv/files/cygwin/postgis.tgz
These seem to work for me with the current Cygwin PostgreSQL
distribution and the most recent 'snapshot' Cygwin DLL but I don't
see why they wouldn't work with the 'current' Cygwin DLL
These were compiled with these Configuration Directives
# Set USE_PG72 to 1 for PostgreSQL version >= 7.2
USE_PG72=1
# Set USE_PROJ to 1 for Proj4 reprojection support
USE_PROJ=1
This is not a 'supported' distribution but I would be interested
in hearing of any problems encountered
Cheers
Norman
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20020508/5330a8b4/attachment.obj>
