[postgis-users] Error creating GIST indexes in Cygwin 7.2.1
Norman Vine
nhv at cape.com
Tue May 14 08:00:45 PDT 2002
Obe, Regina DND\MIS writes:
>I recently upgraded my Cygwin PostGreSQL 7.1 to 7.2.1 and all
>seemed to be
>working fine until I tried to create a GIST index on one of my geometry
>fields.
< snip >
>So I am assuming its a particular record or set of records
>that is causing the problem.
Or, heaven forbid, you have tickled a Cygwin bug.
Do you have access to a PostGIS installation running on
a non-Cygwin system to test this data set there ??
Could you be hitting a 'dynamic memory limit' in Cygwin ??
http://sources.redhat.com/ml/cygwin/2001-04/msg00141.html
Cheers
Norman
