[postgis-users] Error creating GIST indexes in Cygwin 7.2.1
Obe, Regina DND\MIS
robe.dnd at ci.boston.ma.us
Tue May 14 08:01:44 PDT 2002
Norman,
I'll check that out to make sure its not a Cygwin bug. Unfortunately I
don't have access to a non-Cygwin system yet. I do have another Cygwin
system though that is still running PostGreSQL 7.1 - if I do the same load
and create the same GIST index it works fine.
-----Original Message-----
Sent: Tuesday, May 14, 2002 11:01 AM
To: postgis-users at postgis.refractions.net
Subject: RE: [postgis-users] Error creating GIST indexes in Cygwin 7.2.1
Obe, Regina DND\MIS writes:
>I recently upgraded my Cygwin PostGreSQL 7.1 to 7.2.1 and all
>seemed to be
>working fine until I tried to create a GIST index on one of my geometry
>fields.
< snip >
>So I am assuming its a particular record or set of records
>that is causing the problem.
Or, heaven forbid, you have tickled a Cygwin bug.
Do you have access to a PostGIS installation running on
a non-Cygwin system to test this data set there ??
Could you be hitting a 'dynamic memory limit' in Cygwin ??
http://sources.redhat.com/ml/cygwin/2001-04/msg00141.html
Cheers
Norman
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
