[postgis-users] Error creating GIST indexes in Cygwin 7.2.1
Paul Ramsey pramsey at refractions.net
Tue May 14 08:12:14 PDT 2002
This (from the error messages at least) looks like the same bug that
andyturk at searchlight.com uncovered shortly after release of 0.7. It
comes from the new indexing algorithms in 7.2. We have a patch in our
hands from the index implementors (GiST authors Oleg and Teodor) right
now which might fix it. Should be applied before lunch. So do not be too
quick to blame cygwin.
P.
"Obe, Regina DND\\MIS" wrote:
> Norman,
> I'll check that out to make sure its not a Cygwin bug.  Unfortunately I
> don't have access to a non-Cygwin system yet.  I do have another Cygwin
> system though that is still running PostGreSQL 7.1 - if I do the same load
> and create the same GIST index it works fine.
> -----Original Message-----
> From: Norman Vine [mailto:nhv at cape.com]
> Sent: Tuesday, May 14, 2002 11:01 AM
> To: postgis-users at postgis.refractions.net
> Subject: RE: [postgis-users] Error creating GIST indexes in Cygwin 7.2.1
>  Obe, Regina DND\MIS writes:
> >I recently upgraded my Cygwin PostGreSQL 7.1 to 7.2.1 and all
> >seemed to be
> >working fine until I tried to create a GIST index on one of my geometry
> >fields.
> < snip >
> >So I am assuming its a particular record or set of records
> >that is causing the problem.
> Or, heaven forbid,  you have tickled a Cygwin bug.
> Do you have access to a PostGIS installation running on
> a non-Cygwin system to test this data set there ??
> Could you be hitting a 'dynamic memory limit' in Cygwin ??
> http://sources.redhat.com/ml/cygwin/2001-04/msg00141.html
> Cheers
> Norman
> postgis-users mailing list
