[postgis-users] AddGeometryColumn problem
Obe, Regina DND\MIS robe.dnd at ci.boston.ma.us
Thu May 23 14:29:21 PDT 2002
I had that sa,e exact problem too and discovered it was because my
plpgsql.dll my postgres was pointing to was the 7.1.3 version.  I just
replaced the plpgsql.dll with the new one (7.2)  and that resolved the
problem.
-----Original Message-----
From: Roszman, Larry J. [mailto:LARRY.J.ROSZMAN at saic.com]
Sent: Thursday, May 23, 2002 5:13 PM
To: postgis-users at postgis.refractions.net
Subject: RE: [postgis-users] AddGeometryColumn problem
Opps!  Should add: this is a Cygwin 1.3.10 installation on Windows 2000.
Larry
Sent: Thursday, May 23, 2002 5:09 PM
Subject: [postgis-users] AddGeometryColumn problem
The error message
    "SearchSysCache: BadCache id 27"
is produced when adding a geometry column (AddGeometryColumn) with PostGIS
7.1 and PostgreSQL 7.2.1.  This is a "new" installation, and everything
appeared to install okay.  Anything in particular that should be examined?
Thanks,
Larry J. Roszman
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
