[postgis-users] GIST indexing behavior
Chris Hodgson
chodgson at refractions.net
Fri May 24 08:53:25 PDT 2002
Sounds kinda buggy to me... can you send me the table & data?
Chris
Randy.Goss at kimley-horn.com wrote:
> I have an example table that consists of a number of overlapping
> polygons of various sizes. I am using this table to query features
> inside of other features; for example, to find all of the features
> inside of a feature called 'Hillsborough' I run the following query, and
> receive the following results:
> QUERY:
> select name from florida where the_geom~(select the_geom from florida
> where name='Hillsborough')
> RESULTS:
> Plant City
> Tampa
> Temple Terrace
> Ruskin
> Sun City Center
> Hillsborough
> Next, I create a GIST index on the geometry column using the following:
> create index idx_geo on florida using GIST (the_geom GIST_GEOMETRY_OPS);
> Re-running the original query now produces the following results:
> RESULTS:
> Hillsborough
> Why does the query return a single value on the indexed table?
> postgis-users mailing list
