[postgis-users] GIST indexing behavior
Randy.Goss at kimley-horn.com
Fri May 24 07:00:42 PDT 2002
I have an example table that consists of a number of overlapping
polygons of various sizes. I am using this table to query features
inside of other features; for example, to find all of the features
inside of a feature called 'Hillsborough' I run the following query, and
receive the following results:
QUERY:
select name from florida where the_geom~(select the_geom from florida
where name='Hillsborough')
RESULTS:
Plant City
Tampa
Temple Terrace
Ruskin
Sun City Center
Hillsborough
Next, I create a GIST index on the geometry column using the following:
create index idx_geo on florida using GIST (the_geom GIST_GEOMETRY_OPS);
Re-running the original query now produces the following results:
RESULTS:
Hillsborough
Why does the query return a single value on the indexed table?
