[postgis-users] GIST indexing behavior
Dave Blasby dblasby at refractions.net
Fri May 24 09:37:13 PDT 2002
Randy.Goss at kimley-horn.com wrote:
> Why does the query return a single value on the indexed table?
I looked at the code.  I think the index is using "~" as 'contains' and the
non-index uses the "~" as 'contained' - look in postgis.sql.
The standard postgresql functions say that "~" is 'contains' and '@' is
contained, so we need to switch the definition of the '~' and '@' operators.
You're probably the first person to actually use those operators!
dave
