[postgis-users] AddGeometryColumn problem
Roszman, Larry J.
LARRY.J.ROSZMAN at saic.com
Fri May 24 14:02:40 PDT 2002
Regina,
Thanks for the suggestion. Had to remove and rebuild everything!!
Larry Roszman
-----Original Message-----
From: Obe, Regina DND\MIS [mailto:robe.dnd at ci.boston.ma.us]
Sent: Thursday, May 23, 2002 5:29 PM
To: 'postgis-users at postgis.refractions.net'
Subject: RE: [postgis-users] AddGeometryColumn problem
I had that sa,e exact problem too and discovered it was because my
plpgsql.dll my postgres was pointing to was the 7.1.3 version. I just
replaced the plpgsql.dll with the new one (7.2) and that resolved the
problem.
From: Roszman, Larry J. [mailto:LARRY.J.ROSZMAN at saic.com]
Sent: Thursday, May 23, 2002 5:13 PM
To: postgis-users at postgis.refractions.net
Opps! Should add: this is a Cygwin 1.3.10 installation on Windows 2000.
Larry
Sent: Thursday, May 23, 2002 5:09 PM
Subject: [postgis-users] AddGeometryColumn problem
The error message
"SearchSysCache: BadCache id 27"
is produced when adding a geometry column (AddGeometryColumn) with PostGIS
7.1 and PostgreSQL 7.2.1. This is a "new" installation, and everything
appeared to install okay. Anything in particular that should be examined?
Thanks,
Larry J. Roszman
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
