[postgis-users] GiST
Guido Staub
guidostaub at lycos.de
Tue Nov 5 06:37:41 PST 2002
David Blasby schrieb:
>Guido Staub wrote:
>>aren't operators like &<, &>, >>, << implemented yet for GiST-Index Scan?
>>Trying a query with them and using explain I always get as result that
>>seq scan will be used and not index scan
>It should be indexed. Try typing this before your query:
>'set enable_seqscan =off;'
>This forces the postgresql planner to use the index. Postgresql is usually
>pretty bad a determining when to use the GiST index, hence all the traffic on
>histogram2ds to optimize use of the index with the "&&" operator
>dave
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
Now it works. Thanks.
But can you please give an example on how to use histogram2ds?
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20021105/0ca2f7b7/attachment.html>
