[postgis-users] libs not copied during install
Paul Ramsey pramsey at refractions.net
Mon Nov 25 19:59:50 PST 2002
I've committed that change. Under my linux/gmake regime it did no harm.
Norman Vine wrote:
> Paul Ramsey writes:
>>Since I do not have an autoconf set up yet (some day, some day) the only
>>real option seems to be Makefile editing, and you already did that. I
>>can macro-ize the references to 'make' if that will make it (ha, punny)
>>any easyer.
> maybe just using $(MAKE) instead of make will work
>  < documentation @ >
> % info make commands recursion make
> Norman
>>Caffeinate The World wrote:
>>>during make install - the libraries are not copied to the
>>>pgsql-install-dir/lib
>>>also, it shoudn't rely on 'make' but should check for 'gmake'. make on
>>>my BSD system failed so i had to change all occurances of 'make' in
>>>Makefile to 'gmake'.
>>>i also had proj installed in a diff directory than the system directory
>>>for lib, maybe it should allow for that config option as well.
> postgis-users mailing list
