[postgis-users] libs not copied during install
Norman Vine
nhv at cape.com
Mon Nov 25 19:57:23 PST 2002
Paul Ramsey writes:
> Since I do not have an autoconf set up yet (some day, some day) the only
> real option seems to be Makefile editing, and you already did that. I
> can macro-ize the references to 'make' if that will make it (ha, punny)
> any easyer.
maybe just using $(MAKE) instead of make will work
< documentation @ >
% info make commands recursion make
Norman
> Caffeinate The World wrote:
> > during make install - the libraries are not copied to the
> > pgsql-install-dir/lib
> > also, it shoudn't rely on 'make' but should check for 'gmake'. make on
> > my BSD system failed so i had to change all occurances of 'make' in
> > Makefile to 'gmake'.
> > i also had proj installed in a diff directory than the system directory
> > for lib, maybe it should allow for that config option as well.
