[postgis-users] Spatial operators
David Blasby dblasby at refractions.net
Thu Oct 10 09:42:14 PDT 2002
Luis,
The operators are very simple and work on the bounding box of the
geometry.
 A&<B  - true if xmax(A) < xmax(B)
A<< B  - true if xmax(A) < xmin(B)
And the same for A&<B and A>>B.  There are no operators that work in the
Y direction.
The reason these operators exists is to mimic the normal database
operators "<" and "<=".  They dont really have any practical use.
If you want to sort things by Y, I would do something like:
SELECT the_geom FROM mygeom ORDER by ymax(the_geom)
The xmax(geom), ymax(geom), xmin(geom), ymin(geom) returns information
about the bounding box of a geometry.
dave
