[postgis-users] Spatial operators
Chris Hodgson chodgson at refractions.net
Thu Oct 10 10:10:28 PDT 2002
I just committed a change which should have corrected the documentation for
the &<, &>, << and >> operators, as I believe it was backwards.
In addition, I happened to notice that the box3d_overleft() function was
incorrectly written, it was comparing the xmins of both boxes instead of the
xmin with xmax - probably noone experienced this problem, as this function
is not bound to any postgres operators, you'd have to be calling it from C
code... but it's fixed now.
Chris
----- Original Message -----
From: "Chris Hodgson" <chodgson at refractions.net>
To: <postgis-users at postgis.refractions.net>
Sent: Thursday, October 10, 2002 9:33 AM
Subject: Re: [postgis-users] Spatial operators
> I'm sorry... perhaps I had better read the docs myself before suggesting
> someone else should... You're right it is completely unclear... and in
fact,
> it is describes them backwards... probably the best answer you'll find is
in
> the code... or perhaps Dave will give us a better answer...
> Chris
> From: "Luis Mota" <luis.mota at iscte.pt>
> Sent: Thursday, October 10, 2002 9:23 AM
> > First thing, thanks for the very polite answer.
> > I had already seen that page, but it is in no way clear what left and
> > right means. As there is also no example,  I wanted to be sure.
> > Luís
> > Chris Hodgson wrote:
> > >http://postgis.refractions.net/docs/x730.html
> > >RTFM. :-)
> > >Chris
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
