[postgis-users] Questons about current starte of java geometry objects
Paul Ramsey
pramsey at refractions.net
Thu Oct 24 08:54:01 PDT 2002
Committed.
P.
Rueben Schulz wrote:
> Hello.
> Attached are two new files that may be added to the postGIS jdbc
> objects.
> PGbox3d.java includes two new methods to access the point members of the
> box.
> PGgeometry.java now checks if the wkt used to construct geometries
> contains a srid. If present this is removed. To use this class, the
> resultset.getObject() method must know that the field is of type
> geometry. Therefore the query that creates the resultset must be of the
> form "select geom from geomtable".
> Both classes have been tested with postGIS 7.3 and postgresql 7.2.1
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
