[postgis-users] Bug fix for transform() function
Mark Cave-Ayland
mark.cave-ayland at webbased.co.uk
Wed Sep 4 03:03:43 PDT 2002
Hi everyone,
I have recently found a bug in postgis-0.7.1 to do with the transform()
function which causes the backend server process to die when the query
is executed! I was attempting to reproject a BOX3D object with the
following statement (running this on a production system is probably not
advised):
select transform(setSRID('BOX3D(-9.13027162006
45.0826338462,1.96043607225 56.1733415385)'::BOX3D,4318), 27700);
The reprojection causes the server process to die (and terminates both
the client and the server under cygwin). Looking at the source, I found
that the BOX3D geometry is not handled correctly and so I have modified
it to correctly handle the reprojection of the the BOX3D object.
I have enclosed my patch against 0.7.1 which I think gives the correct
response, although I would be grateful if someone could review it since
I'm not that familiar with the reprojection code. Hopefully it will help
other people experiencing the same problem.
Many thanks,
Mark.
Type: application/octet-stream
Desc: transform.patch
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20020904/8b2404a7/attachment.obj>
