[postgis-users] SRID Problem
Frank Koormann
frank.koormann at intevation.de
Fri Sep 6 04:18:22 PDT 2002
* staub at gik.uni-karlsruhe.de <staub at gik.uni-karlsruhe.de> [020906 12:30]:
> Hi,
> I'm trying to load some ESRI shapefiles with the shp2psql command.
> The SRID column shows -1 but I'm having a *.prj file where the Spatial
> Reference System of the uploaded shapefile is specified. So is it
> possible to insert the correct SRID value automatically while uploading
> or do I have to correct the columns manually?
I don't think that shp2pgsql reads the *.prj file, however you can
use the "-s <srid>" switch on the command line to set the correct srid
before uploading the data into PostGIS.
Regards,
Frank
Frank Koormann <frank.koormann at intevation.de>
Professional Service around Free Software (http://intevation.net/)
FreeGIS Project (http://freegis.org/)
