[postgis-users] Using two tables in mapserver
Daryl Herzmann akrherz at iastate.edu
Fri Sep 6 06:11:01 PDT 2002
Hi!
Hope you didn't get this email twice, I think I sent the first one to the
wrong address.  Anyway...
I have a database with two tables.
Table (a) has my data in it.  One of the columns is called sid, which is
an identifier for the data point.
Table (b) has the geometry info with a unique column called sid, which is
the same as sid in table a.
So with Mapserver, I would like to cross-reference these tables.  I bet
dollars to donuts, that I am doing something stupid here!!  Here are the
relevant .map lines
DATA "b.geom from tablea a, tableb b"
FILTER "b.sid = a.sid and a.day = '2000-02-10'"
This dies a horrible death, since OID::text is ambiguous.  And based on
the assembled query, there are other problems....
I could put a geom column on tablea and make it work, but I would like
something more elegant!  Basically, I have many tables and would like them
all to use the geom information in one table.  Maybe the performance would
be too poor?  tableb has only 500 entries in it, but the data tables have
200 million rows or so combined.
TIA
  Daryl
