[postgis-users] Using two tables in mapserver
Jan Hartmann
jhart at frw.uva.nl
Fri Sep 6 08:19:15 PDT 2002
Daryl,
There are many solutions for creating maps based on more than one table.
I generally use a subselect in the DATA statement
LAYER
CONNECTIONTYPE POSTGIS
CONNECTION "your PG server"
DATA "the_geom from
( select map.the_geom, data.myvar
from maptable as map, datatable as data
where map.sid = data.sid
and (... more filter conditions ... )
) as foo
CLASS
expression ([myvar] > 1 and [myvar] < 10)
color 10 20 30
END
CLASS
expression ([myvar] >=10 and [myvar] < 20)
color 20 30 40
END
etc ...
END
I don't think you should use MapServer's FILTER statement. I don't know
if it works on a PostGIS table, but doing your filtering in PostgreSQL
is anyhow much cleaner.
As you can see, the "myvar" variable in the subselect clause is
available to MapServer in its class expressions. This doesn't have to be
a table variable: you can just as well use a computed variable, provided
you give it a synonym, so MapServer can refer to it:
the_geom from
case when data.myvar> 1 and data.myvar < 10 then 1
when data.myvar >=10 and data.myvar < 20 then 2
end as mycolor
) as foo
In this case you can use CLASS expressions like:
CLASSITEM mycolor
CLASS
expression 1
color 10 20 30
END
CLASS
expression 2
color 20 30 40
END
etc ...
For simple cases you can let MapServer itself take care of the class
computations, as in the first example. With multiple tables and complex
computations, the second way quickly becomes more attractive.
Performance should be good, PROVIDED you put indices on your variables:
GIST for geometry, and regular ones for every field you use as a link.
BTW the reason your DATA statement dies so horribly is that you use two
tables without using a join (where a.var=b.var). PostgreSQL will try to
return the cross product of both tables (every row of a combined with
every row of b)!
Hope this helps. Took me some time to figure out!
Jan
Daryl Herzmann wrote:
> I have a database with two tables.
> Table (a) has my data in it. One of the columns is called sid, which is
> an identifier for the data point.
> Table (b) has the geometry info with a unique column called sid, which is
> the same as sid in table a.
> So with Mapserver, I would like to cross-reference these tables. I bet
> dollars to donuts, that I am doing something stupid here!! Here are the
> relevant .map lines
> DATA "b.geom from tablea a, tableb b"
> FILTER "b.sid = a.sid and a.day = '2000-02-10'"
> This dies a horrible death, since OID::text is ambiguous. And based on
> the assembled query, there are other problems....
> I could put a geom column on tablea and make it work, but I would like
> something more elegant! Basically, I have many tables and would like them
> all to use the geom information in one table. Maybe the performance would
> be too poor? tableb has only 500 entries in it, but the data tables have
> 200 million rows or so combined.
Jan Hartmann
Department of Geography
University of Amsterdam
jhart at frw.uva.nl
