[postgis-users] pgsql2shp
David Garnier
david.garnier at etudier-online.com
Fri Sep 13 04:55:21 PDT 2002
le ven 13-09-2002 à 13:33, staub a écrit :
> Hi,
> does anybody know why I can't connect to my own database using
> pgsql2shp?
> Here's the error message:
> could not connect to server: Connection refused
> Is the server running on host localhost and accepting
> TCP/IP connections on port 5432?
It seems that your database isn't configured to accept TCP/IP connection
because:
* it wasn't started with the -i flag or
* it is configured to refuse connections: check data/pg_hba.conf.
Also, make sure your connection parameters are correct
> The other way is working fine using shp2pgsql.
shp2pgsql doesn't use the DB, it just parse shapefiles into a list of
insert statements that you can use later to insert data in the DB later.
Best Regards,
David Garnier
Website: http://dgarnier.etudier-online.com
PGP key: http://www.davidgarnier.com/public_gpg_key.txt
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20020913/45cf5e5f/attachment.pgp>
