[postgis-users] Re:pgsql2shp
Guido Staub staub at gik.uni-karlsruhe.de
Fri Sep 13 06:21:33 PDT 2002
What I wanted to say is, that
shp2pgsql shapefile table db | psql -d db
is running fine and uploading data is no problem. I don't get an error
message about any TCP/IP problems.
So my problem still exists, that I can't get my data out of the table
into a shapefile.
Reading the Online Doc there should not be a problem using the dumper.
It's only the
pgsql2shp [<options>] <database> <table>
command from the commandline, isn't it?
Thanks
Guido
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20020913/ce0f5d1e/attachment.html>
