[postgis-users] Re:pgsql2shp
Chris Hodgson
chodgson at refractions.net
Fri Sep 13 09:24:17 PDT 2002
The command 'psql -d db' DOES NOT use TCP/IP sockets to connect to the db, it uses unix sockets (by default). Whereas, pgsql2shp DOES use TCP/IP sockets. Therefore, the advice that David Garnier gave you, still stands. Check your config, or start your database with the -i flag to allow tcp connections.
Chris
----- Original Message -----
To: postgis-users at postgis.refractions.net
Sent: Friday, September 13, 2002 6:21 AM
Subject: [postgis-users] Re:pgsql2shp
What I wanted to say is, that
shp2pgsql shapefile table db | psql -d db
is running fine and uploading data is no problem. I don't get an error message about any TCP/IP problems.
So my problem still exists, that I can't get my data out of the table into a shapefile.
Reading the Online Doc there should not be a problem using the dumper. It's only the
pgsql2shp [<options>] <database> <table>
command from the commandline, isn't it?
Thanks
Guido
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20020913/77d7ad74/attachment.html>
