[postgis-users] Re:pgsql2shp
Guido Staub
staub at gik.uni-karlsruhe.de
Mon Sep 16 01:40:35 PDT 2002
OK, I've got it. My problem was that I've started the postmaster with
the pg_ctl script but here I couldn't set the -i flag. So now I'm
starting the postmaster with the postmaster file and here it works fine.
Thanks to all.
Guido
Chris Hodgson schrieb:
> The command 'psql -d db' DOES NOT use TCP/IP sockets to connect to the
> db, it uses unix sockets (by default). Whereas, pgsql2shp DOES use
> TCP/IP sockets. Therefore, the advice that David Garnier gave you,
> still stands. Check your config, or start your database with the -i
> flag to allow tcp connections. Chris
> ----- Original Message -----
> From: Guido Staub
> To: postgis-users at postgis.refractions.net
> Sent: Friday, September 13, 2002 6:21 AM
> Subject: [postgis-users] Re:pgsql2shp
> What I wanted to say is, that
> shp2pgsql shapefile table db | psql -d db
> is running fine and uploading data is no problem. I don't
> get an error message about any TCP/IP problems.
> So my problem still exists, that I can't get my data out of
> the table into a shapefile.
> Reading the Online Doc there should not be a problem using
> the dumper. It's only the
> pgsql2shp [<options>] <database> <table>
> command from the commandline, isn't it?
> Thanks
> Guido
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20020916/09de6e65/attachment.html>
