[postgis-users] Re:pgsql2shp
Thomas, Cord cthomas at rand.org
Fri Sep 13 08:58:35 PDT 2002
This may make no sense, but you are talking a bit of apples and oranges -
because "shp2pgsql shapefile table db | psql -d db" is piping to psql - does
that use the same mechanism that the pgsql2shp is using?
Cord
-----Original Message-----
From: Guido Staub [mailto:staub at gik.uni-karlsruhe.de]
Sent: Friday, September 13, 2002 6:22 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Re:pgsql2shp
What I wanted to say is, that
is running fine and uploading data is no problem. I don't get an error
message about any TCP/IP problems.
So my problem still exists, that I can't get my data out of the table into a
shapefile.
Reading the Online Doc there should not be a problem using the dumper. It's
only the
pgsql2shp [<options>] <database> <table>
command from the commandline, isn't it?
Thanks
Guido
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20020913/615b6976/attachment.html>
