[postgis-users] RE: To transform, is PROJ needed.
Chris Hodgson chodgson at refractions.net
Mon Sep 16 09:39:21 PDT 2002
I believe you need to download the proj source and compile it in cygwin, and
install it, before you compile and install postgis (after modifying the
postgres makefile to turn proj support on). Unless you are downloading the
pre-compiled dll's from somewhere else, in which case you should just need
to have them both installed (assuming the postgis.dll was compiled with proj
support)
Chris
----- Original Message -----
To: "postgis" <postgis-users at postgis.refractions.net>
Sent: Friday, September 13, 2002 8:02 PM
Subject: [postgis-users] RE: To transform, is PROJ needed.
> I am using the Windows platform and one of the functions i want to use is
> transform or reproject the spatial data. Do
> I need to install PROJ separately or is that embedded within the
> postgis.dll.
> Regards
> Nyon
> postgis-users mailing list
