[postgis-users] Re:pgsql2shp
Tyler Mitchell
TMitchell at lignum.com
Mon Sep 16 08:40:33 PDT 2002
You can add "-o -i" to add the same option using pg_ctl. Since me startup
script uses pg_ctl this was the only solution for me :)
Tyler
Guido Staub
<staub at gik.uni-karlsruhe.de> To: postgis-users at postgis.refractions.net
Sent by: cc:
postgis-users-admin at postgis.refr Fax to:
actions.net Subject: Re: [postgis-users] Re:pgsql2shp
09/16/2002 01:40 AM
Please respond to postgis-users
OK, I've got it. My problem was that I've started the postmaster with the
pg_ctl script but here I couldn't set the -i flag. So now I'm starting the
postmaster with the postmaster file and here it works fine.
Thanks to all.
Guido
Chris Hodgson schrieb:
The command 'psql -d db' DOES NOT use TCP/IP sockets to connect to
the db, it uses unix sockets (by default). Whereas, pgsql2shp DOES
use TCP/IP sockets. Therefore, the advice that David Garnier gave
you, still stands. Check your config, or start your database with the
-i flag to allow tcp connections. Chris
----- Original Message -----
Sent: Friday, September 13, 2002 6:21 AM
Subject: [postgis-users] Re:pgsql2shp
What I wanted to say is, that
shp2pgsql shapefile table db | psql -d db
is running fine and uploading data is no problem. I don't get an
error message about any TCP/IP problems.
So my problem still exists, that I can't get my data out of the
table into a shapefile.
Reading the Online Doc there should not be a problem using the
dumper. It's only the
pgsql2shp [<options>] <database> <table>
command from the commandline, isn't it?
Thanks
Guido
