[postgis-users] RE: [CYGWIN] No source files from which to build Postgis extension
Norman Vine
nhv at cape.com
Tue Apr 8 13:33:26 PDT 2003
Jason Tishler writes:
> Norman,
> On Mon, Apr 07, 2003 at 10:02:51AM -0400, Norman Vine wrote:
> > for a link to the binary package and the changes I had to make see
> http://postgis.refractions.net/pipermail/postgis-users/2003-March/
> 002260.html
Jason
Thank you for looking at this :-)
< FYI: Jason is the 'official' Cygwin PostgreSQL maintatiner >
> Please submit a patch to <pgsql-patches at postgresql.org> to add the
> missing DLLIMPORT for cpu_index_tuple_cost to
> src/include/optimizer/cost.h.
OK, Will do
> BTW, under 7.3.2-1, I get the following link errors:
<snip>
> 1: undefined reference to `_pg_detoast_datum'
<snip>
> The above error is due to the dllwrap command missing the following
> arguments:
> -L ../../src/backend -lpostgres
Yes , I usually hardwire this into the Makefile
> I used the attached patch to the PostGIS Makefile to workaround this
> "problem." Is this cockpit error on my part? Or, is the patch really
> necessary?
AH... Your makefile patch is the correct solution :-)
TO PostGIS maintainers
Please apply this patch to the PostGIS makefile
Thanks
Norman
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20030408/5936c45a/attachment.obj>
