[postgis-users] Re: [CYGWIN] No source files from which to build Postgis extension
Jason Tishler
jason at tishler.net
Wed Apr 9 06:22:18 PDT 2003
Norman,
On Tue, Apr 08, 2003 at 04:33:26PM -0400, Norman Vine wrote:
> Jason Tishler writes:
> Thank you for looking at this :-)
You are welcome.
> > Please submit a patch to <pgsql-patches at postgresql.org> to add the
> > missing DLLIMPORT for cpu_index_tuple_cost to
> > src/include/optimizer/cost.h.
> OK, Will do
Thanks.
> > BTW, under 7.3.2-1, I get the following link errors:
> [snip]
> > -L ../../src/backend -lpostgres
> Yes , I usually hardwire this into the Makefile
Thanks for the confirmation.
> > I used the attached patch to the PostGIS Makefile to workaround this
> > "problem." Is this cockpit error on my part? Or, is the patch
> > really necessary?
> AH... Your makefile patch is the correct solution :-)
My patch is a workaround *not* the solution. It appears that the
following Makefile line attempted to deal with this issue:
override DLLLIBS := $(BE_DLLLIBS) $(DLLLIBS)
However, the above does not seem to work (anymore).
Additionally, my patch does not handle the Proj4 case.
> TO PostGIS maintainers Please apply this patch to the PostGIS makefile
PostGIS maintainers, please do not apply this patch as is. I'm willing
to help develop a real patch, if there is interest.
Jason
PGP/GPG Key: http://www.tishler.net/jason/pubkey.asc or key servers
Fingerprint: 7A73 1405 7F2B E669 C19D 8784 1AFD E4CC ECF4 8EF6
