[postgis-users] Re: [CYGWIN] No source files from which to build Postgis extension
Norman Vine
nhv at cape.com
Wed Apr 9 08:19:44 PDT 2003
Jason Tishler writes:
> > > I used the attached patch to the PostGIS Makefile to workaround this
> > > "problem." Is this cockpit error on my part? Or, is the patch
> > > really necessary?
> > AH... Your makefile patch is the correct solution :-)
> My patch is a workaround *not* the solution. It appears that the
> following Makefile line attempted to deal with this issue:
> override DLLLIBS := $(BE_DLLLIBS) $(DLLLIBS)
> However, the above does not seem to work (anymore).
true sigh....
> Additionally, my patch does not handle the Proj4 case.
> > TO PostGIS maintainers Please apply this patch to the PostGIS makefile
> PostGIS maintainers, please do not apply this patch as is. I'm willing
> to help develop a real patch, if there is interest.
Plenty of interest !
Any help making PostGIS installation as easy and platform independent
as possible will be *appreciated* :-)
Let us know where we can help.
Thanks again
Norman
