[postgis-users] CVS Stability
Norman Vine
nhv at cape.com
Tue Apr 8 14:48:48 PDT 2003
Paul Ramsey writes:
> To repeat: until the next numbered release (0.8) is out, do not use the
> CVS snapshots unless you are willing to work with experimental and
> tempermental code.
Why not make a branch for the new GEOS enabled PostGIS
and then merge the branch back in once we have the GEOS
issues ironed out ?
http://cvsbook.red-bean.com/cvsbook.html#Branches
This way the CVS PostGIS remains 'solid'
Cheers
Norman
