[postgis-users] FYI: Solution to PostGIS Installation Problems on Cygwin
Will Shaw
wshaw at neo.tamu.edu
Tue Apr 8 20:30:09 PDT 2003
Those of you who have tried to compile postgis with no success have probably
ready many posts about what modifications you need to do. I just wanted to
clarify I few things. First of all you do need to modify the make file to
include:
# Add libraries that libpq depends (or might depend) on into the
# shared library link. (The order in which you list them here doesn't
# matter.)
SHLIB_LINK=$(filter -L%, $(LDFLAGS))
ifeq ($(USE_PROJ),1)
SHLIB_LINK=$(filter -L%, $(LDFLAGS)) -L$(PROJ_DIR)/lib -lproj
else
SHLIB_LINK=$(filter -L%, $(LDFLAGS)) ../../src/backend/libpostgres.a
endif
And secondly, you do need to modify the file
/usr/src/postgresql-7.3.2-1/src/include/optimizer/cost.h to include:
extern DLLIMPORT double cpu_index_tuple_cost;
//extern double cpu_index_tuple_cost;
Now, what no one has mentioned so far is that this last modification will
not work unless you have a java JDK installation in Cygwin. Getting java
into Cygwin is apparently tricky, because I had a lot of problems, but the
easiest way is to download the Blackdown java JDK-1.4.1 for linux from here.
http://www.blackdown.org/java-linux/mirrors.html Follow the directions in
the install-j2sdk file. I wasn't able to get the java plugin or webstart to
work, but you don't need it anyway.
Regards,
Will
