[postgis-users] Error while trying to compile postgis-cvs
Martin Müller
martin.mueller at intevation.de
Thu Apr 10 06:24:43 PDT 2003
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi there,
thanks for the fast help last time. So just to get my coding going on, I
tried to install the posgtis-cvs.tar.gz . First I installed geos which
compiled well after using ./autoconf.
So, when I try to compile postgis, I get the following error:
O2 -Wall -Wmissing-prototypes -Wmissing-declarations -g -I. -DFRONTEND
- -DSYSCONFDIR='"/usr/local/pgsql/etc"' -DUSE_VERSION=72
- -I/usr/local/include/geos -DUSE_GEOS -I/usr/local/include -DUSE_PROJ
- -I../../src/include -c -o postgis_geos_wrapper.o postgis_geos_wrapper.cpp
make: O2: Kommando nicht gefunden.
make: [postgis_geos_wrapper.o] Fehler 127 (ignoriert)
ar crs libpostgis.a postgis_debug.o postgis_ops.o postgis_fn.o
postgis_inout.o postgis_proj.o postgis_chip.o postgis_transform.o
postgis_gist_72.o postgis_estimate.o postgis_geos.o postgis_geos_wrapper.o
ar: postgis_geos_wrapper.o: Datei oder Verzeichnis nicht gefunden
make: *** [libpostgis.a] Fehler 1
I tried to fix it, but with no result. Finally I compiled the
postgis_geos_wrapper.cpp manually and started make afterwards.
This time everything worked fine!
CU,
Martin Müller
P.S.: Sorry for the german output!!! ;-)
_______________________________
"Microsoft isn't evil, they just make
realy crappy operating systems."
Linus Torwalds
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.1 (GNU/Linux)
iD8DBQE+lXCev3XhQ794IQoRAvRxAJwOiO9i0Fi18+KrC92RBOnQXzw7zgCfZ5Uw
12+seByLhCjoJYUXsGWDODo=
=JHCB
-----END PGP SIGNATURE-----
